I've been trying to open some of my files from 2008 on revit 2010 and it doesn't open.I am using a mac and I get the message: '' failed to open file''
what can I possibly do?
I would verify the following items:
1. Version of Revit 2008
Can you verify you are running the latest version of Revit 2008? If not, test the latest build release below:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9408083
Here is a thread I want to potentially rule out:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Unspecified-Error-or-Failed-to-Open-file-
2. Ensure Revit 2010 is up to date
Make sure you have applied the service pack here:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12828862
3. Open in Revit 2009?
Can you verify if the 2008 file opens as expected in 2009? If so, save a 2009 copy and attempt to upgrade to 2010.
4. Audit
Open the project in 2008 with Audit. Save a copy. Repeat for 2009 \ 2010. I want to verify if it opens each subsequent release without jumping releases.
Please let us know if this helps.
Thank you,
