Hi all,
1. Is there a way to customize the type of material Revit will export to DWG? By default, materials are "Architectural" once you import the DWG to MAX...No good if you are using a third party renderer. I exported a DXF to see what material definitions were exported, but I do not know the codes...Is there a DXF code chart somewhere?
2. Interestingly enough, any material field left at "default" in Revit, will export no material definition into MAX. Is there a way to assign some material to the "Default" value in the property panel?
Thank you
regards
gio
