I am setting up a material takeoff schedule for floors, but we have some floors that we must specify in linear ft instead of square feet. I need to calculate only the "tape" floor type as linear feet, while leaving everything else blank, or zero. I tried an if statement for this, but I can't seem to get the calculation to work. How can I achieve what I am trying to get?
Solved by RDAOU. Go to Solution.
You cannot use Text as an IF condition.
You need to use another type of parameter...example: Integer. to represent each type of material.
IE:
