I want to give an ID for each window, which will appear in the plans and elevations. I use the one which comes with revit but it resulted in a number which is repetetive for similar windows..
I would like to tag the windows with my own numbering..
Thanks!
Solved by ennujozlagam. Go to Solution.
did you use the window tag in revit default? same type of window but different window tag number. txs
