While installing a trial verison of Revit 2014 to a 64 bit windows 7 OS, the downolad bar would stop moving forward once a windows saying "Preparing revit content" appeared. I could not pause the installation or cancel it. I eventually had to force quite the installation. I've retried several times to no avail. Any suggestions?
I finally got the installation to finish, however it failed to install Revit. this is what came up.
Please help. Need to learn Revit ASAP.
2014/3/8:14:32:59 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:14:32:59 Patrick PATRICK-HP Path_Length: 149 2014/3/8:14:32:59 Patrick PATRICK-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/3/8:14:32:59 Patrick PATRICK-HP Launch 2014/3/8:14:32:59 Patrick PATRICK-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/3/8:14:32:59 Patrick PATRICK-HP Path_Length: 149 2014/3/8:14:32:59 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIDF5.tmp 2014/3/8:14:35:46 Patrick PATRICK-HP === Setup ended ===
2014/3/8:14:33:00 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:14:33:00 Patrick PATRICK-HP Path_Length: 149 2014/3/8:14:33:00 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIDF5.tmp 2014/3/8:14:33:00 Patrick PATRICK-HP Launch 2014/3/8:14:33:51 Patrick PATRICK-HP Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta... 2014/3/8:14:35:46 Patrick PATRICK-HP Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta... 2014/3/8:14:35:46 Patrick PATRICK-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Patrick\AppData\Local\Temp\_AIDF5.tmp\Setup\RevitSetup.dll 2014/3/8:14:35:46 Patrick PATRICK-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/3/8:14:35:46 Patrick PATRICK-HP PageOpen LaunchDialog 2014/3/8:14:35:51 Patrick PATRICK-HP PageOpen LicenseDialog 2014/3/8:14:35:51 Patrick PATRICK-HP PageOpen ProductInfoDialog 2014/3/8:14:37:06 Patrick PATRICK-HP PageOpen ProductSelectionDialog2 2014/3/8:14:37:27 Patrick PATRICK-HP PageOpen FullProgressDialog 2014/3/8:14:37:29 Patrick PATRICK-HP Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008... 2014/3/8:14:37:41 Patrick PATRICK-HP Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008... 2014/3/8:14:37:41 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2014/3/8:14:38:21 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2014/3/8:14:38:21 Patrick PATRICK-HP Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005... 2014/3/8:14:38:28 Patrick PATRICK-HP Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005... 2014/3/8:14:38:28 Patrick PATRICK-HP Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Patrick\AppData\Local\Temp\vcredist_x86_2005.log"" " 2014/3/8:14:38:51 Patrick PATRICK-HP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2014/3/8:14:38:53 Patrick PATRICK-HP Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX... 2014/3/8:14:38:54 Patrick PATRICK-HP Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX... 2014/3/8:14:38:54 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:39:01 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/3/8:14:39:02 Patrick PATRICK-HP Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX... 2014/3/8:14:39:20 Patrick PATRICK-HP Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX... 2014/3/8:14:39:20 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:39:34 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/3/8:14:39:34 Patrick PATRICK-HP Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX... 2014/3/8:14:39:36 Patrick PATRICK-HP Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX... 2014/3/8:14:39:36 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:39:48 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/3/8:14:39:49 Patrick PATRICK-HP Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN... 2014/3/8:14:39:49 Patrick PATRICK-HP Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN... 2014/3/8:14:39:49 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:40:00 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/3/8:14:40:01 Patrick PATRICK-HP Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX... 2014/3/8:14:40:01 Patrick PATRICK-HP Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX... 2014/3/8:14:40:01 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:40:08 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/3/8:14:40:08 Patrick PATRICK-HP Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX... 2014/3/8:14:40:27 Patrick PATRICK-HP Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX... 2014/3/8:14:40:27 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:40:45 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/3/8:14:40:49 Patrick PATRICK-HP Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX... 2014/3/8:14:40:52 Patrick PATRICK-HP Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX... 2014/3/8:14:40:52 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:41:04 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/3/8:14:41:04 Patrick PATRICK-HP Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN... 2014/3/8:14:41:04 Patrick PATRICK-HP Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN... 2014/3/8:14:41:05 Patrick PATRICK-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:41:16 Patrick PATRICK-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/3/8:14:41:17 Patrick PATRICK-HP Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005... 2014/3/8:14:41:27 Patrick PATRICK-HP Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005... 2014/3/8:14:41:27 Patrick PATRICK-HP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Patrick\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/3/8:14:41:58 Patrick PATRICK-HP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded 2014/3/8:14:42:02 Patrick PATRICK-HP Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar.... 2014/3/8:14:42:18 Patrick PATRICK-HP Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar.... 2014/3/8:14:42:18 Patrick PATRICK-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/3/8:14:42:26 Patrick PATRICK-HP Install DirectX® Runtime Succeeded 2014/3/8:14:42:27 Patrick PATRICK-HP Download Play FaroSDK http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64.... 2014/3/8:14:42:58 Patrick PATRICK-HP Download Complete FaroSDK http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64.... 2014/3/8:14:42:58 Patrick PATRICK-HP Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:14:43:17 Patrick PATRICK-HP Install FaroSDK Succeeded 2014/3/8:14:43:17 Patrick PATRICK-HP Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64.... 2014/3/8:15:13:01 Patrick PATRICK-HP Download Complete RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64.... 2014/3/8:15:13:02 Patrick PATRICK-HP Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Patrick\AppData\Local\Temp\_AIDF5.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:15:38:18 Patrick PATRICK-HP === Setup ended ===
2014/3/8:17:36:26 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:17:36:26 Patrick PATRICK-HP Path_Length: 149 2014/3/8:17:36:26 Patrick PATRICK-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/3/8:17:36:26 Patrick PATRICK-HP Launch 2014/3/8:17:36:26 Patrick PATRICK-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/3/8:17:36:26 Patrick PATRICK-HP Path_Length: 149 2014/3/8:17:36:26 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI4B5.tmp 2014/3/8:17:36:32 Patrick PATRICK-HP === Setup ended ===
2014/3/8:17:36:30 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:17:36:30 Patrick PATRICK-HP Path_Length: 149 2014/3/8:17:36:30 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI4B5.tmp 2014/3/8:17:36:30 Patrick PATRICK-HP Launch 2014/3/8:17:36:31 Patrick PATRICK-HP Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta... 2014/3/8:17:36:31 Patrick PATRICK-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Patrick\AppData\Local\Temp\_AI4B5.tmp\Setup\RevitSetup.dll 2014/3/8:17:36:31 Patrick PATRICK-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/3/8:17:36:32 Patrick PATRICK-HP PageOpen LaunchDialog 2014/3/8:17:36:38 Patrick PATRICK-HP PageOpen LicenseDialog 2014/3/8:17:36:38 Patrick PATRICK-HP PageOpen ProductInfoDialog 2014/3/8:17:51:42 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:17:51:42 Patrick PATRICK-HP Path_Length: 149 2014/3/8:17:51:42 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIE6BA.tmp 2014/3/8:17:51:42 Patrick PATRICK-HP Launch 2014/3/8:17:51:45 Patrick PATRICK-HP === Setup ended ===
2014/3/8:17:51:36 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:17:51:36 Patrick PATRICK-HP Path_Length: 149 2014/3/8:17:51:36 Patrick PATRICK-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/3/8:17:51:36 Patrick PATRICK-HP Launch 2014/3/8:17:51:36 Patrick PATRICK-HP CommandLine 2014/3/8:17:51:36 Patrick PATRICK-HP Path_Length: 149 2014/3/8:17:51:36 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AIE6BA.tmp 2014/3/8:17:51:46 Patrick PATRICK-HP === Setup ended ===
2014/3/8:19:19:30 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:19:19:30 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:19:30 Patrick PATRICK-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/3/8:19:19:30 Patrick PATRICK-HP Launch 2014/3/8:19:19:30 Patrick PATRICK-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/3/8:19:19:30 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:19:30 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI6176.tmp 2014/3/8:19:19:36 Patrick PATRICK-HP === Setup ended ===
2014/3/8:19:19:33 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:19:19:33 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:19:33 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI6176.tmp 2014/3/8:19:19:33 Patrick PATRICK-HP Launch 2014/3/8:19:19:34 Patrick PATRICK-HP Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta... 2014/3/8:19:19:34 Patrick PATRICK-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Patrick\AppData\Local\Temp\_AI6176.tmp\Setup\RevitSetup.dll 2014/3/8:19:19:34 Patrick PATRICK-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/3/8:19:19:34 Patrick PATRICK-HP PageOpen LaunchDialog 2014/3/8:19:19:38 Patrick PATRICK-HP PageOpen LicenseDialog 2014/3/8:19:19:38 Patrick PATRICK-HP PageOpen ProductInfoDialog 2014/3/8:19:34:55 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:19:34:55 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:34:55 Patrick PATRICK-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/3/8:19:34:55 Patrick PATRICK-HP Launch 2014/3/8:19:34:55 Patrick PATRICK-HP CommandLine 2014/3/8:19:34:55 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:34:55 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI7EA7.tmp 2014/3/8:19:34:58 Patrick PATRICK-HP === Setup ended ===
2014/3/8:19:34:56 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:19:34:56 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:34:56 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AI7EA7.tmp 2014/3/8:19:34:56 Patrick PATRICK-HP Launch 2014/3/8:19:34:58 Patrick PATRICK-HP === Setup ended ===
2014/3/8:19:56:01 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:19:56:01 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:56:01 Patrick PATRICK-HP Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US 2014/3/8:19:56:01 Patrick PATRICK-HP Launch 2014/3/8:19:56:01 Patrick PATRICK-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/3/8:19:56:01 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:56:01 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AICCF6.tmp 2014/3/8:19:58:59 Patrick PATRICK-HP === Setup ended ===
2014/3/8:19:56:01 Patrick PATRICK-HP === Setup started on PATRICK-HP by Patrick === 2014/3/8:19:56:01 Patrick PATRICK-HP Path_Length: 149 2014/3/8:19:56:01 Patrick PATRICK-HP Current Directory C:\Users\Patrick\AppData\Local\Temp\_AICCF6.tmp 2014/3/8:19:56:01 Patrick PATRICK-HP Launch 2014/3/8:19:56:02 Patrick PATRICK-HP Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta... 2014/3/8:19:58:59 Patrick PATRICK-HP Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta... 2014/3/8:19:58:59 Patrick PATRICK-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Patrick\AppData\Local\Temp\_AICCF6.tmp\Setup\RevitSetup.dll 2014/3/8:19:58:59 Patrick PATRICK-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/3/8:19:58:59 Patrick PATRICK-HP PageOpen LaunchDialog 2014/3/8:19:59:35 Patrick PATRICK-HP PageOpen LicenseDialog 2014/3/8:19:59:35 Patrick PATRICK-HP PageOpen ProductInfoDialog 2014/3/8:20:01:13 Patrick PATRICK-HP PageOpen ProductSelectionDialog2 2014/3/8:20:01:49 Patrick PATRICK-HP PageOpen FullProgressDialog 2014/3/8:20:01:50 Patrick PATRICK-HP Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar.... 2014/3/8:20:02:12 Patrick PATRICK-HP Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar.... 2014/3/8:20:02:12 Patrick PATRICK-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/3/8:20:02:15 Patrick PATRICK-HP Install DirectX® Runtime Succeeded 2014/3/8:20:02:16 Patrick PATRICK-HP Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64.... 2014/3/8:20:39:34 Patrick PATRICK-HP Download Complete RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64.... 2014/3/8:20:39:35 Patrick PATRICK-HP Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Patrick\AppData\Local\Temp\_AICCF6.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/8:20:39:35 Patrick PATRICK-HP Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1618 2014/3/8:20:39:35 Patrick PATRICK-HP Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
The 1618 error you see at the end of your log file usually indicates that another installation is already in progress and this is causing the Revit installation to fail. In this scenario, the best suggestion is to reboot your system, delete the contents of your Windows temp folder (type %temp% in the Windows Explorer address field to quickly access this location), and then try installing Revit again.
Also, please note that Revit content is being downloaded while the Preparing Revit Content progress meter is displayed so it is important to let this process complete. The length of time required for downloading content varies depending on the number of content packs selected for installation as well as the available Internet connection speed. In some cases, customers have needed to let this process run overnight to ensure that all of the content is downloaded and installed successfully.
Tony Michniewicz
Autodesk Revit QA
