Quick Access Toolbar invisible in Windows 10
Message 1 of 51
Hi everyone.
As you can see at the screenshot, I updated my PC to Windows 10 and the quick access toolbar just turn invisible in Revit 2016. I already tried select integrated graphics on the Nvidia control panel, but the problem persists. Can anyone help me ?
PS: Sorry about my english.
Replies (50)
Message 2 of 51
Anyone? I really need a help here... Smiley Sad
Message 3 of 51
rodrigo.bezerra
Hi Fabricio,
You might wanna check it again. Your Quick Access Toolbar isn't missing, but bellow the ribbon. Try to drag it back.
Regards
Rodrigo Bezerra
Message 4 of 51
Thanks for your answer Rodrigo . I moved the toolbar down because it is invisible on the original place . But when I move back the problem persists .
Message 5 of 51
rodrigo.bezerra
I haven't update my Windows yet. I'll let you know if I find something.
Regards
Rodrigo Bezerra
Message 6 of 51
@Anonymous wrote:
Hi everyone.
Just curious as to where you saw that Windows 10 and Revit 2016 was a supported combination...
Message 7 of 51
I wrote that? No. So if you can't help me, please do not disturb.
It's a common problem with other versions of Revit, I just want to know how to resolve that...
Message 8 of 51
Fair enough.  Here's some help: roll back to a supported operating system.
Message 9 of 51
I can't do that. But thank you for your time!
Message 10 of 51
rmoore3
Weird, 2016's QAT works for me on my test machine but 2014's QAT behaves just like what you are seeing
Message 11 of 51
EK_bja
I got the same problem - just after updating my Revit 2016 and 2015 the toolbars become invisible above Ribbon! I can se it below Ribbon but it take some Screen Area.
Message 12 of 51
rodrigo.bezerra
I'm postponing update my OS until this issues are fix.
I need my notebook working fully operational so I can develop activities
for a post graduation course.
In previous versions of Windows (including 7, which I use), you're able to
run the applications in compatibility mode. Have you guys tried that?
Regards
Rodrigo Bezerra
Message 13 of 51
Hi everyone!
I found a solution.
I changed the title bar color and now I can see that quick access tool again.
But Windows 10 do not allow users to change this parameter. I found this pretty simple article (in portuguese but you can use a translator) with a mod who permit change this title bar color as you can see at this attached screenshot.
Thank you guys for your feedback!
How to a change title bar color in W10:
http://www.tudocelular.com/windows/noticias/n57178/altere-cor-barra-titulos-windows-10.html
Message 14 of 51
It's very easy. you just need to right click to top left of revit window and the text will display for your option, that's it.2016-01-17 11_53_16-AdApplicationButton.png
Message 15 of 51
charlv
Hi All,
Had the same issue. I uninstalled Dinamo 0.9.1 and it now shows my Quick access toolbar above the ribbon. Problem obviously is that if you use Dynamo...
Regards
Charl.
Message 16 of 51
vaughn
removing Dynamo  worked for me to.
Message 17 of 51
buz_ter
I updated Nvidia card drivers and it showed up finally
Message 18 of 51
I had the same problem with Revit 2017, and the solution was to uninstall Dinamo as Charl said. Thank you Charl.
Med
@Anonymous wrote:
Hi everyone.
@Anonymous wrote:
Hi everyone.
Message 19 of 51
charlv
Hi gold.oy89. My Pleasure. Just trying to help the community.
Message 20 of 51
christaitnz
The Quick access toolbar is there but invisible. You can click the last button on the right and move the toolbar to under the ribbon or you can change the colour of your title bar. To change the colour just right click on the desktop and 'Personalize', Click 'Colors', switch the toggle to 'Show color on the title bar' and the toolbar should be visible.
