Revit 2012.
I can not select the walls and windows on the floor plan, but can select everything else like the dim,text, section marks, etc.
I also can choose the walls of the first floor, if they are used as the underlay of the second floor. However, when I am in the first floor plan view, I can not.
Yes, I have 2 views dependant on the one and it does in both. I did however, cut and past the walls in a new project, and wallah,,I can edit them. Something is telling me it is a setting in the level of that floor plan.
Are the elements you cannot select in a Design Option?
Are they on a different Phase?
Are any Plan Regions being used?
Just some quick ideas for troubleshooting.
