Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Light (chandelier) ceiling hosting problem
7 REPLIES 7
Message 1 of 8
zs-17
202 Views, 7 Replies
I can't host many lighting and chandeliers on both horizontal and sloped ceilings, the place on face option does nothing, it's like if the light family doesn't recognise the ceiling face nor the floor slab above it, it works on the work plane option but it is placed upside down on the floor and on the ceiling.
Is there an easy way or a step by step setting to place it on both horizontal and sloped ceilings?
7 REPLIES 7
Message 2 of 8
curtisridenour
in reply to: zs-17
Works fine when placed in an RCP or a 3D view on the face of the sloped ceiling.
Message 3 of 8
curtisridenour
in reply to: zs-17
Also, when you are working with Reference Planes, the side that elements will host to depends on which way you draw the reference plane. See the image below. If you need it to face the other way, you can always use the flipper button in pink.
Message 4 of 8
zs-17
in reply to: zs-17
Hi, I didn't know that the lighting has a flipper too.
Many thanks
Message 5 of 8
in reply to: zs-17
Message 6 of 8
@barthbradley, is there any documentation on the Right to Left vs Left to Right nature of the work plane?
Message 7 of 8
Message 8 of 8
thanks @barthbradley. sad that Autodesk does not have any for their own stuff. I can't find that information anywhere.
Autodesk Customer Advisory Groups
