i am trying to crop out some of my drafting view when placed on sheets but im not seeing a way to do this, is it in fact at all possible?
Solved by ToanDN. Go to Solution.
No. But you can do one of the following:
- add masking regions in the drafting view if the masked area is relatively small, or they may mask adjacent views
- use detail views to draft instead of drafting views
Would you consider a Solid White "Masking" Filled Region on the Sheet? There is a trick for this, if you are interested.
@svalente9GJKH wrote:
Sure, what is the trick?
- draw a detail line on sheet
- make a detail group, keep it on sheet
- place another group instance in a drafting view
- edit group and add filled/masking region, save group
Or you can place a stretchable generic annotation family with a solid filled region to mask anything on sheets.
