Hi everyone,
Is there a way to hide or turn off the sheet number highlighted in yellow?
Thank you
Solved by etienne.royer. Go to Solution.
Solved by RDAOU. Go to Solution.
Solved by ToanDN. Go to Solution.
Edit the viewport type and note the view title family type being used. Find the family from the browser and edit it. Select the sheet number label and uncheck visible box. Load it in project and choose overwrite the exiting.
Refer to the link below
Hi @parkside125 ,
1- Go on the properties of the viewport
2- Look at the name of the family used by the viewport
3- Edit the family (look in the project browser for Annotation Symbols)
4- Use the visible parameter in the family to create a new type without the sheet number
Have a nice day
Étienne Royer
