Hi, Does anyone know how to eliminate the view number and scale in the view name as I showed in the attached file?
Solved by barthbradley. Go to Solution.
Create another View Title Family to use in those instances where you need to show that way.
Open your View Title Family, delete the circle, number and view scale lable you don't wnat to see and then save it under a new name and load it into the Project.
I do not have a circle in View Title Family in order to delete it. But it is showing up inside the file ( please see attached).
I'm not sure how that is possible. Maybe you have more than one in the Project and opened the wrong one to edit.
FWIW:
...maybe your View Title has other TYPES defined within it that have visibility parameters pre-set for the circle and labels for each TYPE?
I have the same issue. Circle is deleted from Anno_view_title family, and when I make changes in that family and load it back to project - everything changes as I changed it in Family - except the Circle. I am using Revit 2022 with BIM 360 and a lot of different models from external sources linked. I am mentioning this only because I am pretty sure I used to modify this family in different projects with different versions of Revit and back then everything worked as I remember this.
