What formats can use revit for export and what are standart file extensions t revit?
Solved by www.TechRoom.bg. Go to Solution.
File extension RFT description: Revit Family Template
File extension RTE description: Revit Template
File extension RVG description: Revit Group
File extension RVT description: Revit Project
File extension IES description: Lighting File
File extension RFA description: Revit Family
Check HERE for all Export formats.
I hope this will help you !
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
