Announcements
Export Revit Topo As Contours
Hi guys,
I created a basic 3D CAD drawing and imported it into Revit to create a topo surface for my current project. As it is only at the concept stage, the topo didn't have to be too accurate but I changed a few points when in Revit to make it reflect the actual surface slightly better. Is there any way to export this topo as a drawing with contours on it?
Thanks in advance,
Murray Smiley Happy
rudi.roux
Hi @Anonymous,
Hope you are well. Smiley Happy
Below is a quick Topo Surface which I created. Typically as you stated, you imported a Topo Surface and then amended the Topo Points where required.
After you made your adjustments, you can export the file as a DWG again. Follow the images below:
ISO View of the Topo Surface:
Front View of Topo Surface: (With Shaded visual styles switched on)
I would recommend that you switch your visual styles to hidden lines or wireframe prior to exporting from Revit.
Simply export the file as indicated above: File >> CAD Formats >> DWG >> Export: "current view/sheet only" >> Next... >> Untick the "Export views on sheet and links as external refrences >> OK.
Below is the layers in CAD which exported from Revit.
ALSO
Prior to exporting, you can take a bit more control over your site Topo and primary/secondary contour line in theSite Settings Dialogue, also under your Revit Visibility/Graphic Overrides >> Model Categories >> Scroll down to Topography and make changes or lines display overrides where needed.
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Hi Rudi,
You are a hero! Beforehand I had exported the drawing as you said but did not know how to change the contour interval settings.
Thank you very much!
Murray
rudi.roux
Hi @Anonymous
Only a pleasure! Smiley Happy If my answer server as a solution for you, kindly accept as a solution so that future community members can benefit from my post.
Keep well! Smiley Happy
Rudi Roux
LinkedIn
