Hello I am working in Revit 2016 and I continue to get the warning "An error has occured while drawing the content of this window" and then my Revit file does not respond and closes.
I have tried to use the file on many different computers in my school but it seems the video card and driver have not been tested is the warning i get under options>graphics.
I have tried restarting my computer, turning off the "use hardware acceleration", and clearing up files but nothing seems to work.
I am worried if this file is now corrupted or something because it has been working fine on these computers up til now.
Thank you,
Tommy V
Hello @Anonymous
Ar you using a 4K display?
Thank you for taking part in our community forum!
Kind Regards,
Same error are above. Using Revit 2016 all updates installed and K4000 with latest drivers.
Any fix would be much appreciated.
Thank you.
Getting the same error while trying to draw a model line in an elevation view. Switching hardware acceleration off makes no difference. Running Revit 2016 with an Nvidia Quadro K2200, two HP Compaq LA2405x monitors.
