How to delete such reference planes. See attached family. Revit 2018.3
Solved by RDAOU. Go to Solution.
Do you get any messages when you try to delete them?
They are user created families and nested parts of a bigger family. Production line changed and now we need to cleanup the old ones and readjust to suit the new production model. There were several other parameters which I already deleted from the family above for privacy reasons till I was left over with the reference planes
Atteched is another sample of a different nested family with dimensions and elements which I am not able to delete
Those are RP, Dims and elements which were added to your custom company templates. Some purposly do that to lock delete (after the finish they rename family to .rft and recreate the .rfa)
If your intention is to delete them and start fresh you need to do so in the .rft files which your family was initiated from, rename it to .rfa and delete them from therein
That worked and I was able to get rid of most unnamed reference planes but there are still some dimensions I am not able to delete. Any ideas
I'm having a similar issue were the reference plane won't let me delete it. I've tried what you said, which is to rename the file type from RFT to RFA. But it still won't let me delete it. I've attached it for reference
