Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Writing a purge utility
2 REPLIES 2
JoelBradley
1535 Views, 2 Replies
I'm a developer, but for the last year or two have been learning and using Revit instead.  I haven't yet delved into coding in Revit.
I am wondering if anyone can give me any idea of how involved it would be (and whether it's even possible) to write a utility that automatically purges Revit files.  Specifically, I would love to be able to schedule a batch file to run overnight that invokes such a utlity to open, purge, and then re-save files (e.g. - purge.exe MyProject.rvt); or, if that's not possible, maybe even something that can run from within a Revit application session and do the same thing at a scheduled time for multiple files in a given folder.
I don't mind figuring it out for myself, but would appreciate any insight anyone can give me on feasibility (and even suggestions on direction) before I try tackling it.
Can anyone shed some light?
Thanks!
Joel
2 REPLIES 2
phildebrandt
in reply to: JoelBradley
Opening and saving files is no problem. I don't think you can invoke the purge command from within a customn app. You would probably have to write some routines that would check for instances of each family type before removing them from the file. I think this is also do-able.
JoelBradley
in reply to: phildebrandt
Belated response (!!) --- thanks for your help, phildebrandt
Autodesk DevCon in Munich May 28-29th
Rail Community
