Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Wall Modulation
0 REPLIES 0
Message 1 of 1
261 Views, 0 Replies
Wall Modulation
Revit allows using hatches over wall faces to represent bricks/blocks. In the fact, the wall modulation is composed by some block modules for instance, 90, 46, 25 centimeters of width.
So, the wall modulation can not be represented by a simple hatch. There is a way to represent the wall modulation by API?
I think is possible to access the wall faces and draw over them 2D objects (lines) to represent the wall modulation. Correct?
Ari
0 REPLIES 0
Rail Community
