Visual Studio 2015
Visual Studio 2015
FRFR1426
Message 1 of 9
Visual Studio 2015
FRFR1426
Does anyone has already tried to compile a Revit addin with VS 2015? I've got a solution with several projects (one for each Revit version, 2013 to 2016) and only the 2016 one compile. The others fail with "csc2.exe exited with code 1". When I look in the object explorer, I see only one entry for RevitAPI.dll. On VS 2013, I see one entry for each version.
An AutoCAD project with a similar structure works, so I think it's a Revit problem. It's like there is a problem with loading the RevitAPI.dll metadata.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Replies (8)
Message 2 of 9
Looks like there are some issues with the 2015 RC that have already been reported:
https://github.com/dotnet/corefx/issues/1238
The issue has been marked as resolved, but presumably you'll need to wait for a new RC build or the final version to receive the fixes.
Message 3 of 9
FRFR1426
OK, I'll wait.
Maxence DELANNOY
Manager
http://wiip.fr
Message 4 of 9
Dale.Bartlett
Now that VS2015 has been released, is there any update on this issue? Thanks, Dale
______________
Yes, I'm Satoshi.
Message 5 of 9
That particular issue seems to have been resolved. I'm now able to compile DLL files with no issue.
I'm able to attach the VS 2015 debugger to a running Revit process, but I'm not able to launch Revit from VS.  The program will briefly open, but then I receive an error message "the program has exited with code -529697949 (0xe06d7363) 'Microsoft C++ Exception'."
I plan on doing some more testing before I decide whether to migrate to VS 2015 or to stick with VS 2012.
Message 6 of 9
Enabling Native Code Debugging allows stops the crashing issue mentioned above from taking place, and allows Revit to be launched from Visual Studio with a debugger attached.
Message 7 of 9
FRFR1426
Seems to work with the last release
Maxence DELANNOY
Manager
http://wiip.fr
Message 8 of 9
drewj
Thanks Colin,
I just switched to the Community version of 2015 (to save a few dollars as I am a single user) from 2013 Pro and was having to attach to process, glad to be able to launch from VS with this advise.
Cheers,
Drew
Message 9 of 9
Troy_Gates
VS 2015 official release is working for me also. Had the same problems with RC build, but great now.
