Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Viewport Types referenced by Schedules?
9 REPLIES 9
Message 1 of 10
bwinterscheidt
1103 Views, 9 Replies
I have a few rogue Viewport Types that cannot be purged, even when no views are placed on sheets, so not truly "used" but still referenced somewhere in the database.  I am trying to figure out exactly how they are referenced, and perhaps then change the reference to another type that I do want to keep, so these others can be purged.
I have been able to locate the offending Viewport Type definitions (Autodesk.Revit.DB.ElementType), go back to the model, and Select by Element ID.  Manually deleting these Viewport Types takes a large number of my *Schedules* (Autodesk.Revit.DB.ViewSchedule) with them, so I figure that the offending reference must be buried there somewhere.
But, the Autodesk.Revit.DB.ViewSchedule does not seem to have any properties/methods that reference these Viewport Types.
For comparison, when non-schedule views are placed on a sheet, an Autodesk.Revit.DB.Viewport is created, whose GetTypeId() method *will* return the Autodesk.Revit.DB.ElementType ID of the Viewport Type definition.
However, no Autodesk.Revit.DB.Viewport is created for schedule views; only an Autodesk.Revit.DB.ScheduleSheetInstance (and my issue persists with or without ScheduleSheetInstances in the model).
I seem to have quickly hit a dead end, and am unsure where to look from here.  Any thoughts?
Perhaps the API doesn't expose what I am trying to find?
9 REPLIES 9
Message 2 of 10
Dear bwinterscheidt,
I can indeed well imagine that the API does not provide much heklp on nthis issue. You could take a look at the object relationship analyser:
http://thebuildingcoder.typepad.com/blog/2010/03/object-relationships.html
Here are some examples of using it and the underlying technique:
http://thebuildingcoder.typepad.com/blog/2012/10/the-temporary-transaction-trick-for-gross-slab-data...
That might prove a useful tool to support your analysis. More than that, I really don't know. Sounds as if you have done a good job exploring already.
Good luck!
Cheers,
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 10
Did you ever find a solution for changing the Viewport Type associated with a schedule? I have 20 schedules that I will need to recreate if not. Ugg
Message 4 of 10
Has anyone found a solution to this?
Message 5 of 10
Provide a sample RVT project please.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Innovation and R&D Lead, AtkinsRéalis
Facebook | Twitter | LinkedIn
Message 6 of 10
Thanks for replying! I can't make a sample file at the moment, because I'm not at the office, and only have access to Revit 2016 in viewer mode. But this can be tested with any schedule: is it possible to change the Viewport Type associated with a schedule?
Message 7 of 10
Ok if I'm getting you right then this code shall help:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                FilteredElementCollector collector = new FilteredElementCollector(CachedDoc);
                collector.OfClass(typeof(Viewport));
                List<Viewport> viewports = collector.Cast<Viewport>().ToList();
                foreach (Viewport v in viewports)
                    try
                        if (v.GetBoxOutline() == null)
                            CachedDoc.Delete(v.Id);
                            CachedDoc.Delete(v.GetTypeId());
                    catch (Exception ex)
                return Result.Succeeded;
                msg = ex.ToString();
                return Result.Failed;
        #endregion
I also prefer to have a sample RVT file to be ableto reproduce the error.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 8 of 10
ycui
in reply to: bwinterscheidt
Have you find a solution for the connection between Viewport Type and Schedule? I have the same problem now... Will be really appreciated if you could share any suggestion.
Yueying
Message 9 of 10
Mustafa.Salaheldin
in reply to: ycui
Have you tried my solution?
If you can supply a sample RVT file this will also help.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 10 of 10
ycui
in reply to: Mustafa.Salaheldin
Hi Mustafa.Salaheldin,
Thanks for the quick response. Could you please test the attached RVT?
If I delete the "No Title Copy1" Viewport type, it will delete my "FURNITURE SCHEDULE - A" schedule from my project. So I think there are some hidden connection between schedule and viewport type in Revit. If you can provide a way to change the schedule's "viewport type" to "Section 1", it also works for me.
Thanks so much for your help. Looking forward to your result.
Yueying
Rail Community
