viewId is not a view? FilteredElementCollector on Rooms
I posted this before but deleted it because I messed up the code and couldn't edit for some reason.  So anyway, my problem is this:
I'm trying to collect all rooms that exist in a specified view, and I'm using a FilteredElementCollector to do so.  I'm calling the constructor that takes a ViewID.
Below is the entirety of my function.  It fails in the inner loop at the line "FilteredElementCollector collLinked = new FilteredElementCollector(linkedDoc, viewID);".  This approach works just fine when collecting family instances by view, but against rooms I get the strange error "viewId is not a view."  Any ideas?
Thanks!
public static List<Room> LoadRoomsFromRevitByView(ElementId viewID)
            List<Room> ReturnRooms = new List<Room>();
            FilteredElementCollector collector = new FilteredElementCollector(ProjectInfo.ProjectDocument);
            IList<Element> elems = collector.OfCategory(BuiltInCategory.OST_RvtLinks).OfClass(typeof(RevitLinkType)).ToElements();
            foreach (Element e in elems)
                RevitLinkType linkType = e as RevitLinkType;
                String s = String.Empty;
                foreach (Document linkedDoc in ProjectInfo.ProjectApplication.Documents)
                    if (linkedDoc.Title.Equals(linkType.Name))
                        try
                            IList<Element> linkedRooms = collLinked.OfClass(typeof(SpatialElement)).ToElements();
                            foreach (SpatialElement eleRoom in linkedRooms)
                                Room room = eleRoom as Room;
                                if (room != null)
                                    ReturnRooms.Add(room);
                        catch (Exception ex)
                            MessageBox.Show("Error: " + ex.Message);
                            continue;
            FilteredElementCollector collRooms = new FilteredElementCollector(ProjectInfo.ProjectDocument, viewID);
            IList<Element> mainRooms = collRooms.OfClass(typeof(SpatialElement)).ToElements();
            foreach (SpatialElement eleRoom in mainRooms)
                if (room != null)
            return ReturnRooms;
It looks to me like you're trying to use the view ID from the active document on a FilteredElementCollector that's looking in a linked document.
If a view ID is specified in a FilteredElementCollector it must belong to the document that the FilteredElementCollector is searching in.
Thanks!
CJModis
So, how to get elements from RevitLinkedInstance on specified view of current document? For example - i want to get elements from section view.
In RevitLinkedInstance property ActiveView is always null.
sgermanoZ2Y2F
Hi - What was your fix for this? Im trying to do the same thing. I have an arch model linked into mine and I can iterate and get all the rooms from the linked model, but when trying to create tags in my model views Im getting this error:
'viewId Parameter name: viewId must be associated with a plan view or section view.'
            Transaction trans = new Transaction(doc);
            trans.Start("ACTRAN");
            Document linkDoc = GetLinkRoomElementIds(uiapp, doc);
            TaskDialog.Show("ROOM COUNT", roomids.Count().ToString());
            View v = doc.ActiveView;
            CreateRoomTags(linkDoc, v);
            trans.Commit();
            return Result.Succeeded;
        private void CreateRoomTags(Document doc, View v)
            for (int i = 0; i < roomids.Count; i++)
                ElementId roomid = roomids[i];
                Element e = doc.GetElement(roomid);
                Room r = e as Room;
                XYZ cen = GetRoomCenter(r);
                UV center = new UV(cen.X, cen.Y);
                doc.Create.NewRoomTag(new LinkElementId(roomid), center, v.Id);
jeremytammik
The view whose id you specify lives in `doc`.
However, you have an open transaction on and are attempting to create a tag in `linkDoc`.
The error is saying: view belongs to doc, not linkDoc.
The view element id may refer to a totally different element in linkDoc, which is not a view.
Just imagine how confused you would be if the element referred to just happened to be a plan view of some kind too, in linkDoc.
Jeremy Tammik
Developer Technical Services
The Building Coder
