Does the Revit API from version 2013 and higher possess the required methods to properly clean up a central file to provide it to a third party for their use? The command would need to do the following:
Is there anything missing in the API that would make it impossible to perform all of these steps? Are there any steps missing that you would recommend also be performed before sending the file to a third party?
Thanks!
It's definately possible - eTransmit, which is availible with subscription does all that.
Hello djb,
I am very interested in the macro you describe. Have you found any way of developing this Macro?
Thanks!
I can concur with Purge in the API, I've tried to create a similar tool to clean up models. Was able to do everything except purge.
