I am using Revit 2014 version.
I could not place Grid dimensions in revit section which is generated by Revit model as it showing Stop symbol and unable to place them: A part of section is being attached
Any reply would be most appreciated.
Madhu
Solved by Aaron.Lu. Go to Solution.
Dear Rao,
I could not reproduce your problem, you can see a video I recorded (open in web browser), I can create dimensions between grids in section view properly.
Dear Rao,
Do you have any design options which related to grids in your project.
