Hi there,
I want to trim some walls using the API. Is there a way to trim walls in the API ?
I know you can use postcommand, but due to the lack of constructor properties, you can't give the trim command a predefined wall selection. So with this option, the user has to select the walls to trim, and I want to automate this without the user having to select manually.
I've read Jeremy's post of the "Built-In Revit AcGe Functionality" but I don't know if this is the proper way to go for ? And if it is, does anybody have an example to do so ?
Can anybody shed some light on this ?
Solved by jeremytammik. Go to Solution.
Dear Remy,
Thank you for your query.
What exactly do you mean by 'trim'?
What would the situation before and after look like?
As far as I can imagine, this would simply mean cutting off one or the other end of an existing wall.
This should be pretty trivial: just modify the wall location curve, and Bob's your uncle.
I hope this helps.
Best regards,
Okay, thanx. I was hoping maybe there would be another way (too actually use the trim functionality as an API call.
