Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Taging Linked Model Rooms
2 REPLIES 2
david.rock
722 Views, 2 Replies
I'm trying to tag all linked model rooms in the current view. Its weird, it looks line the room tags are there, I've added a selection, and it adds room tags to the selection, however none of them are visible.
Any help really apprectiated.
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
<Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)> _
<Autodesk.Revit.Attributes.Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)> _
Public Class TagAllLinkedRoomElementsCmd
    Implements Autodesk.Revit.UI.IExternalCommand
    Public Function Execute(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData, _
                             ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) _
                             As Autodesk.Revit.UI.Result Implements Autodesk.Revit.UI.IExternalCommand.Execute
        Dim activeDBdoc As Document = commandData.Application.ActiveUIDocument.Document
        Dim selSelectionElements As Autodesk.Revit.UI.Selection.SelElementSet = commandData.Application.ActiveUIDocument.Selection.Elements
        Dim objTransation As Transaction = clsRockitTransation.CreateNewTransation("Tag All Linked Room Elements", activeDBdoc)
        If objTransation IsNot Nothing Then
            Dim RoomTagTypeList As List(Of RoomTagType) = clsRockitElements.GetRoomTagTypes(activeDBdoc)
            If RoomTagTypeList.Count > 0 Then
                Dim objRoomTagType As RoomTagType = RoomTagTypeList.Item(1)
                MsgBox(objRoomTagType.Name)
                For Each doc As Document In commandData.Application.Application.Documents
                    Dim eleDocSpatialElements As List(Of Element) = clsRockitElements.Rockit_GetAllSpatialElements(doc)
                    For Each objElement As Element In eleDocSpatialElements
                        Dim objRoom As Room = TryCast(objElement, Room)
                        If objRoom IsNot Nothing Then
                            Dim locationPoint As LocationPoint = TryCast(objRoom.Location, LocationPoint)
                            Try
                                'MsgBox(locationPoint.Point.X.ToString)
                                Dim point As New Autodesk.Revit.DB.UV(locationPoint.Point.X, locationPoint.Point.Y)
                                Dim newTag As RoomTag = activeDBdoc.Create.NewRoomTag(objRoom, point, activeDBdoc.ActiveView)
                                newTag.RoomTagType = objRoomTagType
                                selSelectionElements.Add(newTag)
                                'MsgBox(objRoom.Name & " has been tagged...")
                            Catch ex As Exception
                                'MsgBox(ex.Message & objRoom.Name)
                            End Try
                    Next
                Next
            objTransation.Commit()
    End Function
End Class
2 REPLIES 2
adam.nagy
in reply to: david.rock
If you create the tags through the user interface then they are visible, right?
Maybe you could create one and compare it to the ones you created programmatically using the "Revit Lookup" tool that is part of the Revit SDK. That might give you an idea what is wrong with the ones you created programmatically.
I hope this helps.
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
david_rock
Thank you for the tip, I used the snoopdb tool, but on comparison between the two tags I could not see any difference. I tried to reconsile hosting but they are all OK.
I tried to copy the missing tag to the clipboard. I was thinking if I could copy & paste it, but I recive the following error message. I think it is a bug.
Selection cannot be copied. Can't Copy to Clipboard because of relationships between ElementsRoom Tags : M-RoomTag : Room Tag With Area : id 1497917
Even if there is a method that I can copy all the rooms from a linked model into the current model I could then tag the rooms.I know I can create spaces but they do not always get created successfully.
David
Rail Community
