Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Supporting user interaction with Revit document from REX extension
1 REPLY 1
dmeisinger
593 Views, 1 Reply
I'm trying to create a REX extension that will involve having the user pick points and objects from the current Revit document view and then return to the extension UI, but I'm having problems.  If I just Hide() the window while selecting points and objects, then Show() the window, it works the first time around, but if I want to have the user select another set of points/objects, it fails with the "user aborted the pick operation" issue described in http://forums.autodesk.com/t5/Autodesk-Revit-API/pick-2-points-consecutively/td-p/3080474 ("pick 2 points consecutively").  If I re-run the extension after closing it, the user is able to pick new points and objects, but it would be very difficult (not to mention inefficient) to close and restart the extension every time I need the user to make a selection in the Revit document. Since the main dialog window is shown by the REX framework application and the sequence of method execution leads to closing the extension altogether when the dialog window is closed, I can't perform the selection outside of the form/control code as the other topic suggests.  How can I allow for user interaction with the Revit model (picking points or objects)?  Are REX SDK applications just not meant for this sort of interaction?
1 REPLY 1
Joe.Ye
in reply to: dmeisinger
It looks the you would like to use REX as modeless dialog.
REXes are external commands that support only modal dialogs
The simplify supported workflow is:
-          Select some elements in Revit
-          Open Dialog
-          User change data exposed inside the dialog
-          Do something with  Revit model using API
-          Close the dialog
-          Command succeeded
It could  be great to  support this workflow by  leveraging  the external events framework.
It’s also  not worth to look at the dockage windows framework  and the drag and drop  feature, since Revit API itself has this feature.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Rail Community
