Revit API
Active Member
rickross96
Message 1 of 2 (518 Views)
Specify Print Setup Name
518 Views, 1 Replies
01-11-2012 01:56 PM
I have written a Drawing Issuing Program in VB.net. So far it works with exporting DWGs and DWFs to specific project folders based on the Central Model location. I am now trying to add a PDF printing routine with great difficulty. We have Acrobat Pro installed so we have the Adobe PDF printer installed on machines. I have a Print Setup in our Project Template called “PDF 42x30 FULL-BLK”. I currently have code that will start printing process, but cannot seem to set the PrintManager.PrintSetup. I found a piece of code that seem to look like what I want but continues to fail. Here is the code that I seem to have trouble with.
    Private Sub CreateAndPrintViewSet(ByVal document As Document, ByVal viewSet As ViewSet)
        'Set the print range to the current view
        m_printMgr.PrintRange = Autodesk.Revit.DB.PrintRange.Current
        'Set file name for PDF
        Dim PDFtoFile As String = Path.Combine(m_pdfFloder, m_pdfFileName)
        If Not SetPrintSettings("PDF 42x30 FULL-BLK") Then
            TaskDialog.Show("PrintPDF", "Unable to set Print Settings")
            Return
        End If
        'Set Print Manager to print to File
        m_printMgr.PrintToFile = True
        'Set Print Manager to print to File Name
        m_printMgr.PrintToFileName = PDFtoFile
        'Initailizes Print
        m_printMgr.SubmitPrint()
    End Sub
    Public Shared Function SetPrintSettings(ByVal name As String) As Boolean
        MessageBox.Show("Start Getting Names")
        For Each ps As Element In m_activeDoc.PrintSettings
            If ps.Name = name Then
                If m_printMgr.PrintSetup.CurrentPrintSetting Is DirectCast(ps, IPrintSetting) Then
                    Dim trans = New Transaction(m_activeDoc)
                    trans.Start("PDF 42x30 FULL-BLK")
                    m_printMgr.PrintSetup.CurrentPrintSetting = DirectCast(ps, IPrintSetting)
                    trans.Commit()
                    Return True
                End If
                Return True
            End If
        Next
        Return False
    End Function
After I get this working, I need to set the Adobe Save As window to the correct location.
ADN Support Specialist
augusto.goncalves
Message 2 of 2 (511 Views)
Re: Specify Print Setup Name
01-12-2012 05:42 AM in reply to: rickross96
Have you tried the sample at <<Revit SDK>>\Samples\ViewPrinter\CS ?
It is similar to want you described.
Augusto Goncalves
Augusto Goncalves
Autodesk Developer Network
