In Revit API, I can find parameter by get_Parameter(BuiltInParameter paramId).
then, how can i find BuitInParameter Id by using parameter?
Solved by ollikat. Go to Solution.
Some answer.
I'm not sure whether I understand your question, but how about Id property of the Parameter? From the id object you can get the integerValue, which in turns corresponds the value inside the BuiltInParameter enum.
Hope it helps
Good!
Please remember also to mark this as "Solved" so that other forum users can easily see that there's a resolution for this issue (although the topic could be better...).
