Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Setting WALL_KEY_REF_PARAM before NewWall()
1 REPLY 1
chuck.han
792 Views, 1 Reply
I want to set WALL_KEY_REF_PARAM before I call NewWall() so that, just like using the UI, I can create walls with the start and end points are NOT the centerline.  Is this possible?
Thanks in advance, Chuck
1 REPLY 1
saikat
in reply to: chuck.han
HI Chuck
Unfortunately, there isn’t any way to set the location line *before* any wall creation but we can definitely set this property once a wall has been created and consequently alter the location.
Hope this works for you
cheers
Saikat
Saikat Bhattacharya
Senior Manager - Technology Consulting
Rail Community
