Revit API
Distinguished Contributor
chuck.han
Message 1 of 2 (304 Views)
Setting WALL_KEY_REF_PARAM before NewWall()
304 Views, 1 Replies
06-20-2012 09:52 AM
I want to set WALL_KEY_REF_PARAM before I call NewWall() so that, just like using the UI, I can create walls with the start and end points are NOT the centerline.  Is this possible?
Thanks in advance, Chuck
HI Chuck
Unfortunately, there isn’t any way to set the location line *before* any wall creation but we can definitely set this property once a wall has been created and consequently alter the location.
Hope this works for you
cheers
Saikat
Employee
saikat
Message 2 of 2 (216 Views)
Re: Setting WALL_KEY_REF_PARAM before NewWall()
07-30-2012 05:02 PM in reply to: chuck.han
HI Chuck
cheers
Saikat
Saikat Bhattacharya
