I want to set WALL_KEY_REF_PARAM before I call NewWall() so that, just like using the UI, I can create walls with the start and end points are NOT the centerline. Is this possible?
Thanks in advance, Chuck
Solved by saikat. Go to Solution.
HI Chuck
Unfortunately, there isn’t any way to set the location line *before* any wall creation but we can definitely set this property once a wall has been created and consequently alter the location.
Hope this works for you
cheers
Saikat
