Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Set MIN and MAX for the Spatial Field Manager
1 REPLY 1
sobon.konrad
438 Views, 1 Reply
Is it possible to set a MIN and MAX for the spatial field manager result? I am trying to compare results acorss multiple analysis and the fact that legend gets always set to that given data set min and max makes it impossible. Is there a way to set the min and max for the legend?
1 REPLY 1
in reply to: sobon.konrad
Not that I have found. The legend just uses the MIN and MAX values from your data. I had a similar issue and my solution was to pick a MAX value and then when sending the data to the Spatial Field Manager, if a value was larger than MAX, I passed in MAX instead (since I didn't care about values higher than MAX). In my case, my MIN was always 0 based on the data. This gave me consistent legends across analyses.
Hope that helps.
Rail Community
