selection set
selection set
Ning_Zhou
selection set
Ning_Zhou
is here a way to persistently highlight elements, or at least create loadable selection set? i.e. Manage > Selection > Load Selection
for instance, API's fail or cancel will highlight related elements, but it's not persistent.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
   foreach (Element e in new FilteredElementCollector(commandData.Application.ActiveUIDocument.Document).OfClass(typeof(Wall)))
      elements.Insert(e);
   message = "whatever";
   //return Result.Succeeded;
   //return Result.Failed;
   return Result.Cancelled;
is it doable w/o using extra dialogbox?
or is it possible to create loadable selection set using API?
what i want to achieve is creating Dynamo node based on API's dll using zero touch method, not good at Python yet so don't know if it's doable using Python, but if Python can work then C# API should work too, below are links for similar request.
http://www.revitforum.org/dynamo-bim/27507-creating-selection-set.html
http://www.revitforum.org/dynamo-bim/27550-create-selection-set.html
Mustafa.Salaheldin
Tell me if it works like a charm
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //SelectionFilterElement sf = new SelectionFilterElement();
                FilteredElementCollector collector = new FilteredElementCollector(cmdData.Application.ActiveUIDocument.Document).OfClass(typeof(Wall));
                List<Element> elements = collector.Cast<Element>().ToList();
                List<ElementId> Ids = new List<ElementId>();
                foreach (Element e in elements)
                    elemSet.Insert(e);
                    Ids.Add(e.Id);
                cmdData.Application.ActiveUIDocument.Selection.SetElementIds(Ids);
            catch (Exception ex)
                msg = ex.ToString();
        #endregion
Please don't forget to mark the reply as an answer if it satisfies your need.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Ning_Zhou
right, as simple as that, pretty basic stuff that UIDocument do have selection method, typical overthinking leads to brain damage, too much coffee perhaps, thanks Mustafa for your quick reply and solution!
before i mark your answer, would you mind confirming that it is not yet possible to create or manipulate loadable selection set using API, maybe i missed something again?
Ning_Zhou
did quick search on Revit API help file, yes, loadable selection set is indeed available, SelectionFilterElement, i knew i missed something simple again.
