Hi everyone here.
We recently developed complex door families, made with nested families managed by shared parameters.
These families just work fine.
We want to schedule door instances in our projects. The trouble is that we cannot show the shared parameters values as we would like to. Like in the properties dialog box, their syntax is : "Nested family name : Type name", and to extract correct data we really just need "Type name".
I perfectly understand that in the properties dialog box it is necessary to have both, because "Type 1" could be in "Nested family A" and "Nested family B", so you have to know from which family you will apply "Type 1".
But in schedules that would be great to have a "formatting" or "appearance" function that enables the user to show only type names. In that case of course he should no longer be able to change the parameter value.
I don't want to create new parameters to store only type names as Autodesk EPS proposed us, because that would add around 50 new parameters to the already existing 50 ones.
I had a look at the API possibilities, but didn't see a way to achieve my goals.
API-speaking, I think this is linked to the fact that when the StorageType of the parameter is ElementId, AsValueString() is called and this function returns the string "Family name : Type name". I'd rather get and show the FamilySymbol.Name property.
Do you have an idea of what could be done ? Or any workarounds ?
Many thanks in advance.
MV
I'm with you on that one, being able to display type name only of a type parameter in a schedule would be awesome. I currently do the same as peterjegan, it's a pain though as it means that I end up creating multiple almost-identical families could easily be combined and driven by a few type parameters.
I've not really messed around much with shared nested families so I'm not too sure, but maybe you can get what you want that way.
Hi guys,
Thanks for your answers.
Your workaround is really impossible to set up in our case.
Not only theoretically speaking it breaks all Revit logic regarding what are families and types, but it also increases the number of families way too much.
If we consider we have 40 nested families with an average of 5 different types, we would have to create (and maintain !!!) 200 families !
Any ideas from other users, or Revit dev teams ?
Would that be a possible software and/or API request ?
Cheers.
M.V.
Dear Maxime,
Thank you for your request.
I submitted the wish list item CF-1987 [API wish: Scheduling nested families -- 10138780] on your behalf for the functionality you suggest, as this issue requires exploration and possibly a modification to our software. Please make a note of this number for future reference.
I hope this helps.
Best regards,
Hi Jeremy,
Thanks a lot for publishing the request. The reference should not be too difficult to remember since it is my year of birth
Do you have any ideas of a possible workaround, in the meantime ?
Thanks a lot.
M.V.
Daniela,
I don't think you can get additional information from the nested family to display in your schedule. Basically, this is what the OP is looking for.
Is there a reason why you can't name your family "10.rfa" and your type "10"?
