Revit API
Active Member
RayRay_46
Message 1 of 6 (854 Views)
Schedule - calculated value / field
854 Views, 5 Replies
02-21-2013 02:14 PM
hi,
Using the ScheduleDefinition.GetSchedulableFields it is possible to iterate through the available (shared) parameters and add or insert (addfield or insertfield) them to the created schedule.
However I wish to add a calculated value / calculated field to the schedule. This field does not show up in GetSchedulableFields because this field has to be added 'on the fly'. In the API there is a schedulefieldtype.formula member which suggest it may be possible to add a calculated field. Does anyone know how to add a calculated field because I am running out of ideas
regards,
Raymond
ADN Support Specialist
jeremytammik
Message 2 of 6 (756 Views)
Re: Schedule - calculated value / field
03-14-2013 04:22 AM in reply to: RayRay_46
Dear Raymond,
Yes, sorry, currently not possible. Revit 2013 provided a first stab at a schedule API, to be fledged out in future, e.g. to access individual values.
Cheers, Jeremy.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Valued Contributor
YarUnderoaker
Message 3 of 6 (641 Views)
06-01-2013 03:27 PM in reply to: jeremytammik
Hi.
Is this possible in Revit 2014? I can find how  to add calculated fields.
jeremytammik
Message 4 of 6 (637 Views)
06-01-2013 05:00 PM in reply to: YarUnderoaker
Sure. Look at the new SDK samples:
  • ScheduleAutomaticFormatter
  • ScheduleCreation
  • ScheduleToHTML
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Valued Contributor
YarUnderoaker
Message 5 of 6 (628 Views)
06-02-2013 12:45 AM in reply to: jeremytammik
Exactly, thank you. I habitually use the SDK 2013 and was looking for methods in documentation and forgot that there is already a new one :smileyhappy:
Valued Contributor
YarUnderoaker
Message 6 of 6 (625 Views)
06-02-2013 01:59 AM in reply to: YarUnderoaker
Unfortunately I still can't see what to do for creating calculated fields :smileysad:
