Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Save command code
3 REPLIES 3
923 Views, 3 Replies
Save command code
Hi All,
Apologies for the very very basic question but i have never really done any coding before and i am trying to teach myself C# to program Revit API.
I have gone through the first plugin guide and the Hello world guide and both of these have helped.
For my next task i want to modify the hello world code to make revit do a file save before the pop up box.
Could anyone please give me an idea of what code i need to write to make Revit save?
After this i would like to look into doing a command which reloads all of the Revit links in the project. Do you think this would be possible?
Many thanks
Mike
Tags (1)
3 REPLIES 3
akira.kudo
There are some methods for saving,  you can use Document::Save() for instance like below. If you need to use the SaveAsOptions, there is a sample code in the SDK help. Please find the attached jpg.
And for reloading rvt links, you can use the RevitLinkType::Load() like below. it uses for load or reload a Revit link from disk.
<code_begin>
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            View view = uidoc.ActiveView;
            using (Transaction tx = new Transaction(doc))
                tx.Start("reload link");
                FilteredElementCollector collector = new FilteredElementCollector(doc);
                         IList<Element> elementos = collector.OfClass(typeof(RevitLinkType)).ToElements();
                         foreach (Element e in elementos)
                                       RevitLinkType linkType = e as RevitLinkType;
                    Debug.Print(linkType.Name);
                    // Loads or reloads the Revit link from disk. The link will be loaded from its currently-stored path.
                    linkType.Load();
                tx.Commit();
            doc.Save(); //Saves the document.
            // Save(SaveOptions) // Saves the document.
            // SaveAs(String) // Saves the document to a given file path.
            // SaveAs(String, SaveAsOptions) // Saves the document to a given file path.
            // SaveAs(ModelPath, SaveAsOptions) // Saves the document to a given path.
            Debug.Print("Hello World");
            return Result.Succeeded;
<code_end>
Please find an attached sample project in the zip. And please let me know if it does not match with what you want to do.
I hope this helps.
PS... I am working on your question for 2013 now . Please hold on.
Akira Kudo
Developer Technical Services
Autodesk Developer Network
in reply to: akira.kudo
Akira,
Thanks for your support.
Look forward to the 2013 Solution!
Mike
akira.kudo
Again Mike-san,
I am really sorry for delay due to our events.
Unfortunately we do not expose any direct methods that third-party developers can reload the revit link model in Revit 2013 via API.
A workaround we have now is that you delete the Revit linked model, and its corresponding Revit link type. Then create a new Revit link type by using the updated Revit model file, and finally create a revit linked model in the same place.
However, this would be time-consuming process.
Please let me know if you need further assistance or if I may close this case.
Best Regards,
Akira Kudo
Akira Kudo
Rail Community
