Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Rotation in slope
3 REPLIES 3
nitinjambhale
822 Views, 3 Replies
Rotation in slope
Hello friends,
I m struggling to rotate a family in slope.
Please help.
Thanks.
-Nitin.
3 REPLIES 3
SinghManish
in reply to: nitinjambhale
Dear Friend,
I am manish i am facing same problem in rotation of families.
while i am using
ElementTransformUtils.RotateElementDocument,Family Id, axis, Rotation Angle);
I am not Getting that
1. How to calculate Axis.
2. Rotation angle.
Manish Singh
Joe.Ye
Hi Nitin,
Here is a sample showing how to rotate an element.
public void RotateColumn(Autodesk.Revit.DB.Document document, Autodesk.Revit.DB.Element element)
    XYZ point1 = new XYZ(10, 20, 0);
    XYZ point2 = new XYZ(10, 20, 30);
    // The axis should be a bound line.
    Line axis = document.Application.Create.NewLineBound(point1, point2);
    ElementTransformUtils.RotateElement(document, element.Id, axis, Math.PI / 3.0);
What's problem when rotate the sloped family? Please give more detailed information about what kind of element?   It is better to upload a very simple model to explain how to you want to rotate it.
BTW, if you just want to rotate a sloped column, you can change the column's "Cross-Section Rotation"  parameter value to rotate the column.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
nitinjambhale
in reply to: Joe.Ye
HI joe
Thanks for the reply. Its working now. There was some misunderstanding.
Thanks.
-Nitin
Rail Community
