Is there a way (utility, program, add-in, etc.) to export the Identity Data of a Revit Family to the AutoCAD block when exporting Revit views/sheets to AutoCAD DWGs?
For example,
Manufacturer: XXX
Model: XXX
Assembly Code: XXX
Description: XXX
Randy
Solved by Joe.Ye. Go to Solution.
I think this post in ADN DevBlog can answer this question.
Joe,
I'm having the same problem, but I don't clearly understand what I need to do. I'm not familiar with lisp's. If you could help that would be great.
I have a Revit model that is being provided by another contractor. They have put the time in tagging all of the electrical equipment to the correct naming ( which appears in the Identity data in the properties tab in revit ) .
My problem is that I have to take .rvt models & .dwg models and merge them all into one .dwg file for the client. I would like the identity data to show up in the .dwg file so the client has all of the correct information. Is this the solution I'm looking for or is it even possible?
Anthony
