I see in a similar post that this feature wasn't posible, but I'm hoping it may have been added but not documented somewhere.
http://forums.autodesk.com/t5/revit-api/replace-text-in-text-note-and-keep-formatting/td-p/3479758
I'm trying to edit a TextNote.Text to define only certain words as Bold, Underline, or Italics, like we can with the GUI. Has this been implemented in Revit 2014 or Revit 2015?
Solved by arnostlobel. Go to Solution.
Unfortunately, the answer is No, it has not been implemented yet. Modifying style on parts of a text note is still not possible to do via the API.
