Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit 2014 API to open revit family file
2 REPLIES 2
1303 Views, 2 Replies
I have current revit project opened in Revit User Interface.(i am using Revit 2014)
I am opening a website through Revit add-in Ribbon and download the revit files.
now i want that the downloaded revit file should be opened as soon as i finish downloading through the windows form.
i tried OpenAndActivate but can't declare "commandData", as my (download revit) code is in different file. Is there any way i can open the downloaded revit file in current project.
2 REPLIES 2
raunoveb
If you want to download file(s) then you could encapsulate the code that deals with downloading in a different method in a static class (e.g. FamilyDownloader).
Let's say your command (that activates on button click) looks like this:
public Result Execute(ExternalCommandData revit, ref string message, ElementSet elements)
    UIApplication application = revit.Application;
    Document document = application.ActiveUIDocument.Document;
//After downloading these files you should add path to each Family file into a List or other type of collection you can later loop through List<string> fileList = FamilyDownloader.download();
foreach(string path in fileList){
document.LoadFamily(path);
} return Result.Succeeded; }
 In this example .download() method returns a list of paths where Family files were downloaded to. Be sure to correct me or add some other information if it seems that I misunderstood your problem.
in reply to: raunoveb
thank you for the code. i have used the similar code and it downloads the revit files and loads the family.
but i want to open the loaded family symbol in currently opened project. i am using
PromptForFamilyInstancePlacement but its not allowing me to add the family symbol. my code is somewhat like this:
public void DL(String url)
loadFamily(fs[0].FullName);
this will download revit file and stroe in folder then i use loadfamily method to place family symbol in opened project.
  public void loadFamily(String f)
            String fname = Path.GetFileNameWithoutExtension(f);
            Family family =  null;
            FamilySymbol familyFound = null;
            Transaction t = new Transaction(s_document, "Test");
            t.Start();
            s_document.LoadFamily(f, out family);
            FilteredElementCollector familyCollector = new FilteredElementCollector(s_document);
            familyCollector.OfClass(typeof(FamilySymbol));
            foreach (FamilySymbol sym in familyCollector)
                if (sym.Family.Name == fname)
                    familyFound = sym;
            t.Commit();
            UIDocument uidoc = new UIDocument(s_document);
            uidoc.PromptForFamilyInstancePlacement(familyFound);
any suggestions please. Thank you.
Rail Community
