Revit API
Active Member
joostschlebaum
Message 1 of 3 (308 Views)
Revit 2013 PickObject
308 Views, 2 Replies
10-31-2012 04:18 AM
The API PickObject function doesn't work anymore with Revit 2013.
I tried to edit the code with help of the migrating blog post of Jeremy's, but without succes.
This is the code:
                        SheetFilter selFilter = new SheetFilter();
                        Selection sel = uiapp.ActiveUIDocument.Selection;
                        pickedRef = sel.PickObject(ObjectType.Element, selFilter, "Select sheet.");
                        Element elema = pickedRef.Element;
 Its the pickedRef.Element; wich gives me an error.
Does someone know how to fix this?
Thanks!
Joost
Hi Joostschlebaum,
in Revit 2011 and 2012, yourReference.Element can be used,
in 2013, you need to use
yourDocument.GetElement(yourReference.ElementId).
Cheers,
Revitalizer
Valued Contributor
Revitalizer
Message 2 of 3 (303 Views)
Re: Revit 2013 PickObject
10-31-2012 05:17 AM in reply to: joostschlebaum
Hi Joostschlebaum,
Cheers,
Revitalizer
Active Member
joostschlebaum
Message 3 of 3 (300 Views)
10-31-2012 05:44 AM in reply to: joostschlebaum
Hi Revitalizer,
That's the key! Awesome!
Thank you very much sir!
