I have an Asus with Windows 7 OS 64 bit.
Here's the installation log files and a screen in the attachments :
2015/1/29:18:33:33 Angelo STARWARS === Setup started on STARWARS by Angelo ===
2015/1/29:18:33:33 Angelo STARWARS Launch
2015/1/29:18:33:33 Angelo STARWARS CommandLine /url "http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_Italian_Win_32_64bit_wi_it-IT_... /SN 900-49214987 /PK 829E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2015/1/29:18:34:16 Angelo STARWARS === Setup ended ===
2015/1/29:18:33:34 Angelo STARWARS === Setup started on STARWARS by Angelo ===
2015/1/29:18:33:34 Angelo STARWARS Launch
2015/1/29:18:33:41 Angelo STARWARS Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/SETUP_x64.t...
2015/1/29:18:34:15 Angelo STARWARS Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/SETUP_x64.t...
2015/1/29:18:34:16 Angelo STARWARS PageOpen LaunchDialog
2015/1/29:18:45:20 Angelo STARWARS PageOpen LicenseDialog
2015/1/29:18:45:20 Angelo STARWARS PageOpen ProductInfoDialog
2015/1/29:18:45:20 Angelo STARWARS PageOpen ProductSelectionDialog2
2015/1/29:19:03:52 Angelo STARWARS PageOpen FullProgressDialog
2015/1/29:19:03:54 Angelo STARWARS Download Play KB958314ATLX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314ATL...
2015/1/29:19:03:56 Angelo STARWARS Download Complete KB958314ATLX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314ATL...
2015/1/29:19:03:56 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:04:05 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2015/1/29:19:04:05 Angelo STARWARS Download Play KB958314MFCX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314MFC...
2015/1/29:19:04:16 Angelo STARWARS Download Complete KB958314MFCX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314MFC...
2015/1/29:19:04:16 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:04:29 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2015/1/29:19:04:29 Angelo STARWARS Download Play KB958314CRTX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314CRT...
2015/1/29:19:04:31 Angelo STARWARS Download Complete KB958314CRTX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314CRT...
2015/1/29:19:04:31 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:04:42 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2015/1/29:19:04:43 Angelo STARWARS Download Play KB958314OPENMPX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314OPE...
2015/1/29:19:04:44 Angelo STARWARS Download Complete KB958314OPENMPX86 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314OPE...
2015/1/29:19:04:44 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:04:56 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2015/1/29:19:04:57 Angelo STARWARS Download Play KB958314ATLX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314ATL...
2015/1/29:19:04:58 Angelo STARWARS Download Complete KB958314ATLX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314ATL...
2015/1/29:19:04:58 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:05:03 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2015/1/29:19:05:05 Angelo STARWARS Download Play KB958314MFCX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314MFC...
2015/1/29:19:07:29 Angelo STARWARS Download Complete KB958314MFCX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314MFC...
2015/1/29:19:07:29 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:07:42 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2015/1/29:19:07:43 Angelo STARWARS Download Play KB958314CRTX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314CRT...
2015/1/29:19:07:45 Angelo STARWARS Download Complete KB958314CRTX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314CRT...
2015/1/29:19:07:45 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:07:54 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2015/1/29:19:07:57 Angelo STARWARS Download Play KB958314OPENMPX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314OPE...
2015/1/29:19:07:58 Angelo STARWARS Download Complete KB958314OPENMPX64 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/KB958314OPE...
2015/1/29:19:07:58 Angelo STARWARS Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:08:05 Angelo STARWARS Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2015/1/29:19:08:05 Angelo STARWARS Installing .NET Framework Runtime 3.5 SP1 Language Pack: C:\Autodesk\WI\Autodesk Revit 2013 /q /norestart /c:"install.exe /qn"
2015/1/29:19:08:05 Angelo STARWARS Install .NET Framework Runtime 3.5 SP1 Language Pack Failed Failure is ignored, Result=2
2015/1/29:19:08:07 Angelo STARWARS Download Play DIRECTX http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/DIRECTX.tar...
2015/1/29:19:10:28 Angelo STARWARS Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/DIRECTX.tar...
2015/1/29:19:10:28 Angelo STARWARS Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2015/1/29:19:12:01 Angelo STARWARS Install DirectX® Runtime Succeeded
2015/1/29:19:12:02 Angelo STARWARS Download Play FaroSDK http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/FaroSDK.tar...
2015/1/29:19:12:24 Angelo STARWARS Download Complete FaroSDK http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/FaroSDK.tar...
2015/1/29:19:12:24 Angelo STARWARS Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\Angelo\AppData\Local\Temp\FaroSDK.log"
2015/1/29:19:13:04 Angelo STARWARS Install FaroSDK Succeeded
2015/1/29:19:13:05 Angelo STARWARS Download Play RVT2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/RVT2013_x64...
2015/1/29:19:28:51 Angelo STARWARS Download Complete RVT2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/RVT2013_x64...
2015/1/29:19:29:05 Angelo STARWARS Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\it-it\RVT2013\RVT2013.mst;C:\Users\Angelo\AppData\Local\Temp\_AI65B.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:56:18 Angelo STARWARS Install Autodesk® Revit® 2013 Succeeded
2015/1/29:19:56:19 Angelo STARWARS Download Play RVT2013_it-it http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/RVT2013_x64...
2015/1/29:19:56:44 Angelo STARWARS Download Complete RVT2013_it-it http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/RVT2013_x64...
2015/1/29:19:56:45 Angelo STARWARS Installing Autodesk® Revit® 2013 Language Pack: TRANSFORMS="C:\Users\Angelo\AppData\Local\Temp\_AI65B.tmp\_la2E9A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:56:52 Angelo STARWARS Install Autodesk® Revit® 2013 Language Pack Succeeded
2015/1/29:19:56:53 Angelo STARWARS Download Play CM2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/CM2013.tar....
2015/1/29:19:57:54 Angelo STARWARS Download Complete CM2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/CM2013.tar....
2015/1/29:19:57:54 Angelo STARWARS Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:19:58:19 Angelo STARWARS Install Autodesk Material Library 2013 Succeeded
2015/1/29:19:58:20 Angelo STARWARS Download Play CMILB2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/CMILB2013.t...
2015/1/29:19:59:48 Angelo STARWARS Download Complete CMILB2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/CMILB2013.t...
2015/1/29:19:59:48 Angelo STARWARS Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/29:20:00:07 Angelo STARWARS Install Autodesk Material Library 2013 - Base Image Library Succeeded
2015/1/29:20:00:08 Angelo STARWARS Download Play CMILL2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/CMILL2013.t...
2015/1/29:20:05:05 Angelo STARWARS Download Aborted CMILL2013 http://edutrial.autodesk.com/SWDLDDLM/2013/RVT/WI/{88A96CBF-22C1-4315-9A23-5197D84A7CE4}/CMILL2013.t...
2015/1/29:20:05:05 Angelo STARWARS Install Autodesk Material Library 2013 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2015/1/29:20:05:27 Angelo STARWARS Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2015/1/29:20:06:03 Angelo STARWARS Rollback Autodesk Material Library 2013 Succeeded
2015/1/29:20:06:11 Angelo STARWARS Rollback Autodesk® Revit® 2013 Language Pack Succeeded
2015/1/29:20:10:40 Angelo STARWARS Rollback Autodesk® Revit® 2013 Succeeded
2015/1/29:20:10:40 Angelo STARWARS Rollback FaroSDK Failed Failure is ignored, Result=1619
2015/1/29:20:10:40 Angelo STARWARS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/1/29:20:10:52 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2015/1/29:20:10:57 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2015/1/29:20:11:02 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2015/1/29:20:11:10 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2015/1/29:20:11:16 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2015/1/29:20:11:23 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2015/1/29:20:11:32 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2015/1/29:20:11:42 Angelo STARWARS Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
What can I do for resolve?
Hi Bibbion,
This forum is for API/programming question,
I'm moving this to installation forum.
