Revit API
New Member
m.walk
Message 1 of 8 (675 Views)
Revisions on sheet
675 Views, 7 Replies
12-30-2010 01:50 PM
Is there a way to access the revisions on sheet information in a viewsheet?  I can get the project revisions, but have not been able to find a way to access any information about the revisions shown on the revision schedule on a sheet.
There is an accessible revisions on sheet parameter however I cannot get anything meaningful out of it.   Has anyone had any luck with this?
david.rock
Message 2 of 8 (477 Views)
Re: Revisions on sheet
06-24-2012 09:39 PM in reply to: m.walk
Sorry I don't have a solution, did you have any luck on this? I have 100 sheets and I need to add a revision to every one of them.
When I look at the "Revisions on sheet" parameter storage type it is set to None :-(
David
Employee
saikat
Message 3 of 8 (434 Views)
07-26-2012 02:36 PM in reply to: david.rock
Hi
The current API does not allow accessing this parameter and further working with it. However it is logged with the Development team to consider implementing in future.
Sorry for the bad news
cheers
Saikat Bhattacharya
New Member
timwinter
Message 4 of 8 (280 Views)
08-20-2013 04:31 PM in reply to: saikat
Any movement on this?  It's a MAJOR sore point for our drafters and their carpal tunnel...
Active Contributor
cshha
Message 5 of 8 (267 Views)
08-21-2013 09:17 AM in reply to: timwinter
I believe that this has been added in Revit 2014
See the ViewSheet.GetAllProjectRevisionIds & ViewSheet.GetAdditionalProjectRevisionIds, as well as the SetAdditionalProjectRevisionIds method.
The "additional" methods refer to revisions that have manually been added, while the "all" method also retrieves revisions that are due to revision clouds being visible in the view.
Distinguished Contributor
Ning_Zhou
Message 6 of 8 (258 Views)
08-21-2013 08:32 PM in reply to: cshha
not quite understand that "additional" stuff? is that extra project revision added using API? seems i cannot add it using normal UI or perhaps i missed something?
from chm it defines as "the project revisions that are additionally included in the sheet's revision schedules", what does it mean?
looks like no relevant info. in sample SDK, will be great if someone can post short coding sample.
Active Contributor
cshha
Message 7 of 8 (248 Views)
08-22-2013 07:45 AM in reply to: Ning_Zhou
The "additional" revisions are the ones that are manually placed on the sheet using the "Revisions On Sheet" window, that appears in the Properties tab for every sheet.
The revisions that are not "additional" are ones that are placed through the use of revision clouds.
Ning_Zhou
Message 8 of 8 (240 Views)
08-22-2013 06:51 PM in reply to: cshha
thanks cshha for clarification.
looks like thses "additional" revisions are still the revisions added through normal Sheet Issues/Revisions window, just not yet instantiated w/ revision clouds by user.
not quite sure if it's useful? we're more concerned w/ numbering system which is too restrictive.
