I am thinking this is a simple question but I am not sure.
I am wondering if there is a way to simply retrieve the colors and/or materials from a Revit drawing's collection of elements within the Revit file.
For example, my imagination of this process is the following:
Loop through all elements
Within loop, get element.
Within loop, check if element has color or material assigned.
Within loop, do what I need to do to element/object.
End Loop
I hope this makes sense.
Thank you for your time.
Unfortunately its not that simple. Retrieving the color and material depends on what you want to do. Are you treating the color as independent of material? I ask because material itself has a color property.
What sort of elements are we talking about. Do you have a sample or use case?
Gopinath
