Retrieving all elements
Hey !
I have to retrieve all elements from the document (without the need of a user selection) to get all information about Face, Mesh, Vertex... I have to export those data to a rendering engine. I have no idea how to do that and the only exemples I found are about getting data from a selected element.
Best !
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
This should help to get back "all" the elements: http://thebuildingcoder.typepad.com/blog/2010/06/filter-for-all-elements.html
But actually it seems you only need the visible elements:
IList<Element> GetAllModelElements( Document doc )
  List<Element> elements = new List<Element>();
  FilteredElementCollector collector
    = new FilteredElementCollector( doc )
      .WhereElementIsNotElementType();
  foreach( Element e in collector )
    if( null != e.Category
      && e.Category.HasMaterialQuantities )
      elements.Add( e );
  return elements;
Then you need to retrieve the geometry from each element you are interested in.
There are many topics on Jeremy's blog concerning this: http://thebuildingcoder.typepad.com/blog/2010/01/analyse-building-geometry.html
I hope this helps.
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
It works, thank you so much !
But I'm not sure that I'm using it correctly. Here is my code:
UIApplication uiApplication = cmdData.Application;
                UIDocument uiDocument = uiApplication.ActiveUIDocument;
                List<double> listData = new List<double>();
                Options geoOptions = uiApplication.Application.Create.NewGeometryOptions();
                if (geoOptions != null)
                    geoOptions.ComputeReferences = true;
                    geoOptions.DetailLevel = DetailLevels.Fine;
                FilteredElementCollector collector = new FilteredElementCollector(uiDocument.Document).WhereElementIsNotElementType();
                foreach (Element e in collector)
                    if (e.Category != null && e.Category.HasMaterialQuantities)
                        elements.Add(e);
                foreach (Element elem in elements)
                    GeometryElement geoElement = elem.get_Geometry(geoOptions);
                    // Get geometry object
                    foreach (GeometryObject geoObject in geoElement.Objects)
                        // Get the geometry instance which contains the geometry information
                        GeometryInstance geometryInstance = geoObject as GeometryInstance;
                        if (geometryInstance != null)
                            foreach (GeometryObject instObj in geometryInstance.SymbolGeometry.Objects)
                                Solid solid = instObj as Solid;
                                if (solid == null || solid.Faces.Size == 0)
                                    continue;
                                Transform transform = geometryInstance.Transform;
                                // Get the faces from solid
                                foreach (Face face in solid.Faces)
                                    Mesh mesh = face.Triangulate();
                                    foreach (XYZ point in mesh.Vertices)
                                        listData.Add(point.X);
                                        listData.Add(point.Y);
                                        listData.Add(point.Z);
What about getting information about the Transformation ?
