Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Read/Write Revit files
1 REPLY 1
452 Views, 1 Reply
I'm looking for a way to to read and update Revit files and I'm not sure if the Revit API can do what I want so any help would be greatly appreciated!
Can the revit API be used to create a "stand alone application" to read/update Revit files? (Much like the RealDWG can be used to create an application that can read/write dwg files)
As I understand an installation of a Revit product is needed for development purposes but is it also needed to run a seperate host application?
1 REPLY 1
Joe.Ye
Revit plugi-ns/addins can only run within Revit. Yes, So installation of Revit is needed before run custom external command.   There is no equivalent library like RealDWG for Revit so far.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Rail Community
