Railing Path
Railing Path
Message 1 of 8
Railing Path
I'm wondering if Revit API allows edit the path of existing railing elements.
Please let me know if there's any way to implement this or any workaround.
Thank you for your help in advance.
Jinsol
Replies (7)
Message 2 of 8
Aaron.Lu
Dear Jinsol, As far as I know, there is no such API.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Dale.Bartlett
Put aside accessing an existing railing path, is it possible to create railings (ie new path) via the api?
______________
Yes, I'm Satoshi.
Message 4 of 8
Can we have mouse events in Revit APIs. I want to create addins which allows me to draw line using mouse.
So I want to use mouse events . I am new in Revit so please guide me that is there any mouse events in Revit Api or not
Message 5 of 8
Dale.Bartlett
Ok, lazy me...
Help file:
private void CreateRailing(Document document, Stairs stairs)
    Transaction trans = new Transaction(document, "Create Railings");
    trans.Start();
    // Delete existing railings
    ICollection<ElementId> railingIds = stairs.GetAssociatedRailings();
    foreach (ElementId railingId in railingIds)
        document.Delete(railingId);
    // Find RailingType
    FilteredElementCollector collector = new FilteredElementCollector(document);
    ICollection<ElementId> RailingTypeIds = collector.OfClass(typeof(RailingType)).ToElementIds();
    Railing.Create(document, stairs.Id, RailingTypeIds.First(), RailingPlacementPosition.Treads);
    trans.Commit();
I just need to confirm that I can create standalone in the absence of stairs. Dale
______________
Yes, I'm Satoshi.
Message 6 of 8
Dale.Bartlett
Ok, it appears that Railings require an existing Stair.
 Create
Automatically creates new railings with the specified railing type on all sides of a stairs element.
Is there a suggested workaround? Invisible stairs? Dale
______________
Yes, I'm Satoshi.
Message 7 of 8
Dale.Bartlett
Sorry Mouse Events should be a new topic.
______________
Yes, I'm Satoshi.
Message 8 of 8
Dale.Bartlett
bump
To summarise, is it possible to create railings via API without exisiting stairs (ie free-standing)? My research says no. Thanks, Dale
______________
Yes, I'm Satoshi.
