Revit API
Active Contributor
nitinjambhale
Message 1 of 7 (352 Views)
"PI" - Pipe Command
352 Views, 6 Replies
10-04-2012 12:06 AM
Hello Guys,
How can i forcefully select required pipe in mouse pointer by pressing "PI" from code.?
Any suggestion Appreciable.
-Nitin.
HI Nitin,
Hope Jeremy's blog post can help  you to change the current pipe type.
http://thebuildingcoder.typepad.com/blog/2010/11/launching-a-revit-command.html
ADN Support Specialist
Joe.Ye
Message 2 of 7 (316 Views)
Re: "PI" - Pipe Command
10-10-2012 02:35 AM in reply to: nitinjambhale
HI Chris,
Not sure I got your idea.
Please clarify the question in detail.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Active Contributor
nitinjambhale
Message 3 of 7 (311 Views)
10-10-2012 06:09 AM in reply to: nitinjambhale
ok,
Here i m trying one more time.
There is shortcut command 'PI' to automatically get Pipe to draw in mouse pointer in Revit Mep 2013.
So i have designed one win app that shows various pipe images that are real pipes in revit. After clicking one of the pipe image and using 'PI' functionality  i m able to get pipe in mouse pointer .
But revit automatically taking random pipe in mouse pointer instead of what i clicked.
Is there any way to do this?
Thanks & Regards,
-Nitin.
Joe.Ye
Message 4 of 7 (281 Views)
10-15-2012 03:27 AM in reply to: nitinjambhale
HI Nitin,
Joe Ye
Contractor
Active Contributor
nitinjambhale
Message 5 of 7 (277 Views)
10-15-2012 05:31 AM in reply to: Joe.Ye
Thanks for the reply.
I will sure try it.
-Nitin.
Active Contributor
nitinjambhale
Message 6 of 7 (256 Views)
10-17-2012 11:18 PM in reply to: Joe.Ye
Hey,
Its working like magic.
Thanks Joe & Jeremey.
-Nitin.
New Member
rridlen
Message 7 of 7 (211 Views)
10-29-2012 09:37 AM in reply to: nitinjambhale
Nitin,
  Would it be possible for you post the code for this?  I'm trying to do the same thing for the "duct" command.
thanks
