Hello Guys,
How can i forcefully select required pipe in mouse pointer by pressing "PI" from code.?
Any suggestion Appreciable.
-Nitin.
Solved by Joe.Ye. Go to Solution.
HI Chris,
Not sure I got your idea.
Please clarify the question in detail.
ok,
Here i m trying one more time.
There is shortcut command 'PI' to automatically get Pipe to draw in mouse pointer in Revit Mep 2013.
So i have designed one win app that shows various pipe images that are real pipes in revit. After clicking one of the pipe image and using 'PI' functionality i m able to get pipe in mouse pointer .
But revit automatically taking random pipe in mouse pointer instead of what i clicked.
Is there any way to do this?
Thanks & Regards,
-Nitin.
HI Nitin,
Hope Jeremy's blog post can help you to change the current pipe type.
http://thebuildingcoder.typepad.com/blog/2010/11/launching-a-revit-command.html
Nitin,
Would it be possible for you post the code for this? I'm trying to do the same thing for the "duct" command.
thanks
