Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Project units
1 REPLY 1
sanjaymann
279 Views, 1 Reply
Project units
How do I get to know the projects units. Its in Decimal feet or Millimeters or Meters.
Thanks and Regards
1 REPLY 1
in reply to: sanjaymann
If you are using Revit 2014 SDK try using
GetDisplayUnitType Method which will get you the display unit for the UT_Length unit type.
In Revit 2015 this method has become obsolete, you will need to use GetFormatOptions(UnitType.UT_Length).DisplayUnits instead.
Rail Community
