Hi I'd like to modify the project informations like the adress, number, ... But I don't find the location of these parameters. I wanted to something like :
parameter p = doc.GET_PARAMETER(adress)
p.set(string)
but it doesn't work..
Can somebody help me plz?
thx!
Solved by sabatierae. Go to Solution.
Dear Sabatierae,
Are you using RevitLookup?
Have you explored the database with it?
Where do you see this information in the user interface?
Have you looked at the project information element in RevitLookup?
Cheers,
Jeremy
Jeremy thx you for your fast answer.
Yes I'm using the Revit Lookup and I've found my parameters (attachement). But I don't know how to modify them..
Thx for your help.
Ops I found it finaly..
It's
doc.ProjectInformation.BuildingName = "name";
Modification of parameter values is one of the basic topics covered in the getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Cheers,
Jeremy
